twistedpneumatic
I'm recapping my analog board as a suggestion from someone at VCF. Should I just replace all the electrolytic with equivalent ones or are there any other types of caps that I should look out for and replace?
Massive recaps usually do not pay out IMHO.
I think I was never able to fix anything by doing recaps. I tried a few times, then I realized it was wasted time & money: unless you know a cap is failing, you're basically replacing good old caps with good new caps.
That being said, if you can't make a proper failure diagnosis and if you're confident you won't add new issues (damage PCB tracks, solder caps with inverted polarity) then it may be worth a try... still it's a longshot.
If you need a bit of equipment to test components and are on a tight budget, I recommend the LCR-T1 for less than $20 shipped. The probes are garbage, but the unit itself is remarkably accurate and will test a wide variety of components. There are less-expensive versions of the same unit, since the MCU source is open, it's more a matter of cosmetics.
The probes are nothing much; just some cheap "grabbers" attached to short length of ribbon cable, terminated in male pins. My things-to-do-list includes adding some real probe jacks to the thing.
I've been surprised once or twice when testing a "house numbered" device and finding out that what it really was, as opposed to what I thought it was. (e.g. JFET vs. BJT or even SCR)
