carlsson
On the Apple IIe, did you bleach all the keys or only those badly discoloured? Now it looks like those few keys are significantly lighter grey than the others, as well as slightly more shiny.
What I've found with both with the Atari and the Apple is that decolourising keys by immersing them in an activated solution is not as risk-free as painting cases with a paste.
Tez
When I processed keyboard keys, I gave them a stir about every 30 minutes. That would get the bubbles off, mix up the solution, and turn the keys over (I wasn't sticking them down with anything). It took mine about a half a day in the heat/sun.
Are you putting them in and leaving them alone, or are you giving them a stir every once in awhile?
The keys are probably mixed up in the factory from many batches so they are not all the same with respect to plastic and UV mix. I would expect the shades to be different kind of like the many amiga keyboards I have seen where the spacebar is yellowed and the other keys are fine.
It is very good to have this pointed out. I've read the opinion from quite a number of people assured it is the heat, not the light that causes a reaction. While placing items in the sunlight, it would be easy to mistake one for the other. However when using an UV lamp, it becomes obvious it doesn't generate much heat.harpo said:The other thing to remember is that the UV is VERY important.
@ Lorne / Tezza
Get this!! Our Retr0brite process has been validated by another very experienced chemist (harpo) over at Atari Age!!
That's all I need to prove that we have got it absolutely right in the way we are going about it. I am absolutely made up, as I was looking for someone impartial to validate my chemistry reasoning all along.
Result!!!! Well done guys!!
:mrgreen:
(Quoting: Harpo)
You need to use concentrations in the 12-15% range.
(Quoting: Harpo)
(Quoting: Harpo)
My feeling is that those individuals who have observed degradation and roughening of the surface of their plastic cases probably used too high a concentration of peroxide. If you stay on the dilute side and use the catalyst and UV so that only reaction with the bromine is favored, you should get an outstanding result.
