falvesjr
How long will it last?
Hey guys,
I'd read about Retr0bright a few months ago and thought it was a great idea. Thanks to all involved in developing this!
Anyway, I'm coming to a point that I need to make a batch to de-yellow some C64 cases and some 1541 cases. I have skimmed this whole thread, but am left wondering about a few things...
- Do you find that, in principle, a liquid bath does a better/more even job than the gel?
- If I make a tub of H2O2 + Oxy + Water big enough for the parts I mentioned, how long will it last? Will I be able to do several cases, one after another in the same solution or will it stop working after X amount of plastic has been exposed or some amount of time?
- Should I add more Oxy over time?
- Does it make any difference if I use tap water or should I use distilled water?
- Has anyone found a good ratio of H2O2 (strength?) to Oxy to Water for larger batches?
Thanks for your thoughts and any guidance you can give me!
-F
Hey guys,
-F
