johnq
This might turn out to be a long running thread.
A while back I got a 8032-32B PET, or so I thought. It turned out to be a franken PET with a 8032 case, 2001-N board and a CRT. Not only that the 2001-N had a mix and match of wrong chips, and lots of missing chips.
More info on that here if you want to know the history:
Fast forward a year and I've now decided to try and repair the 2001-N.
Assembly 320351
It was missing pretty much all the socket chips, so RAM, ROM, CPU, PIA which I've replaced with known good, or equivalents (for the ROMs)
I've used these ROM adapter boards in VIC-20/C64's so I know they work and have tested them with a custom ROM tester.
First thing I did was hook up the motherboard to power without any of the chips in.
Power rails are all stable and present. +5V, -5V, +12V
Next I checked the reset line - working as expected.
I then inserted a 6502 NOP adapter and checked the address lines and logic. All working as well. So 6502 seems to be functioning.
Inserted 6502, RAM, ROMs, powered on and no magic smoke. So far so good.
I don't have a 9" CRT for this board so have connected up my RBG2HDMI adapter set to the PET 9" Profile.
Powered on am getting something on the display but not what I expected. No beep, no text, just alternative squares.
First off the line in the middle of the screen, I think that might be some incorrect setting on my RGB2HDMI PET Profile. Though I've tried adjusting various settings and this seems to be the best display I get. So maybe a problem with the PET or maybe the RBG2HDMI
The squares however - this is not good.
Found this post where someone was having the same issues:
Well in my case I have the RAM inserted, and all RAM chips have been tested ok. I've checked the address/data lines on the RAM chips with a scope and can see data on the lines and it looks ok.
I've also tried the PETTESTER ROM and see the same issue.
One thing is I don't have any PIA's inserted. Looking at the schematic if I'm not wrong these should only be needed for the keyboard and IEEE. With them not inserted it should not cause these video issues correct?
I've replaced 2 logic chips that were running hot and cleaned up some corrosion under one of the socket chips. Luckily no track damage.
Any tips of where to start troubleshooting next?
I've got plenty of hardware tools to assist in the repair. DMM, Scope, logic analyzer.
I'm also wondering if the main board has been swapped from another machine?
Can anyone identify is this is all original parts?
PET 8032
Motherboard Assy 320351 E (PCB part no. is 320350 Rev B)
Also confusing is one of the ROM chips is a 901447-29
which according to the list is a editor ROM is for a Screen editor for BASIC 4, normal keyboard, no CRTC
No CRTC?! Is this ROM also incorrect?
It has the following ROMS - which also appear to be in the wrong locations:
901447-29
901447-10
901465-02
901465–20
The other ROMs are missing.
PET 8032
901447-29
901447-10
901465-02
901465–20
Assembly 320351
Bottom Right = No Ram just Character ROM, ESD7 HIGH (image stable)
