The H osc (multivibrator) is inside that IC. Ideally if you cannot get the schematic for your set, the data sheet on the IC will help a lot, the components around that IC will be part of a standard circuit.
If you have a video monitor where the picture is locking, but then drifting over time with horizontal shifting, there is a way to narrow down where the problem likely is and even a partial schematic will help.
The first move is to find out if the H scan oscillator frequency is stable. If its not, then in the locked condition, any frequency shift will manifest itself as a horizontal movement shift.
Firstly the H sync is disconnected, usually by disconnecting its feed into the IC or sync discriminator circuit by lifting one leg of a coupling capacitor The H osc will then "free run". You can adjust the H hold until the picture is floating by horizontally. And see how stable that creep rate is, or if it intermittently changes, suggesting the H osc frequency is intermittently changing.
If its not the H osc frequency deviating, it could be a problem with the incoming sync level (this results in a phase shift) or the comparator stage where the H sync is compared with the H scan pulse, possibly in a diode discriminator circuit there, where the incoming sync is compared to a pulse which is derived from the H osc, but usually picked off downstream from the actual osc.
In cases of intermittent behavior in a circuit that amounts to a phased locked loop, it is often necessary to break the loop like this because any change inside the loop, by an intermittent component, will be partly counteracted by the loop behavior.
Don't start shot gun replacing parts without any reasonable evidence that a particular part is defective (I agree with Dwight 100% )
