Replacing the screen of a Compaq Portable 486c
felixzero
Fontainebleau, France
Hello everyone,
One afternoon, I was browsing leboncoin.fr (a French classified advertisement website) and found an intriguing ad for an "old computer" close to me with just a blurry picture and a dirt cheap price. Turned out it was a Compaq Portable 486c and I walked home with it :D
As could be expected, the computer was not working at all. When plugged and powered on, all I could hear was a small click every few seconds. I first suspected the power supply, but it ran fine when the computer was unplugged (stable voltages and the fans where spinning). After removing boards one by one, I identified the issue: the 5V supply was shorted to ground on the motherboard. Turned out the 486 CPU was dead. After finding the same model (in my case, a 33MHz 486DX), the computer could boot:
Yeah! I could have a look at the content of the (still working) hard disk. Considering the presence of AutoCAD and various professional pieces of software, it is obvious that it was a professional computer for an engineer. No surprise, considering that they were sold for at least 6000 USD back then.
But there is something obviously wrong on this computer. The screen is flickering a lot, everything is fuzzy and the colors are completely wrong. It is almost usable in text mode, but don't even think of running Windows (3.1, installed) or a game:
After unplugging and re-plugging each of the ribbon cables (sometimes this helps), tweaking the calibration pots of the screen (changed the colors but no actual improvement to image stability) and having a look at the inside of the screen (looking for misplugged cable or bulged capacitor or anything obvisouly wrong), I concluded the screen is deceased. A quick search on the Web shows that is seems to be a very common failure mode of these computers.
Then, I decided to sell it as-is on eBay but changed my mind: there is something I haven't tried yet. What if I could simply replace the screen?
Part 1: What to buy?
The manual of this computer (which can be found as PDF here, for instance) lists this part as 128902-001. The website impactcomputers.com claims to sell some for 80$ but this is a lie. Once you order and pay, they never ship and to have to open a complaint to get your money back. I wonder how much they earn from people placing orders and forgetting about them... Anyway, this is not the way to go.
I could read the actual P/N of the screen on its sticker. It is a LQ10D016 from Sharp. New old stock can be found on Aliexpress for 165€ (~190$) but I don't wish to put *that much* in repairing this computer. I went with my "plan B": buying a similar model and figuring out a way to plug it to the computer.
The original screen uses a 30-pin ribbon connector. There are no datasheet available on the Web. Judging from how they are grouped in pairs on the VGA card, I assume this is some case of LVDS interface. It also provides 2 DC voltages: 5V and 12V. I could not find any other screen using an interface similar to this one. Anyone knows what it could be?
Instead, there are many industrial screens with similar specifications (640x480, 10.4" TFT LCDs) sold all over eBay and Aliexpress using a way more standard D-shaped 31-pin connector (plus, mostly standard pinouts and available datasheet). So I bought a LQ104D1VG11 screen on eBay for 48€ and a matching controller board (25€). The plan is to connect to the computer using the VGA port instead.
In the meantime, I simply used an external monitoring, reinstalled MS-DOS, Windows and put some games.
I got the parts yesterday!
Part 2: Receiving the parts and mounting the screen
First, I unpacked everything and checked that it is working. The cable screen goes to the controller, the fluorescent tubes to the inverter board and the VGA cable to the computer. Yep, I works:
One issue arises: how to mechanically install the new screen, which has different dimensions (generally smaller in all directions) and different screw holes. Also, I want to minimize the damage I inflict to the original hardware. This means I would rather avoid to drill holes in the case unless it is absolutely necessary.
The solution I found? I retrieved the frame of the dead screen (which has all the proper mounting bracket) and installed the new one inside. Here is the frame without the screen:
Here is my "step-by-step guide in doing a dirty job":
1. Remove the following corner (using a Dremel) in the metal frame because the screen won't go in it otherwise:
2. Butcher this corner of the screen. (Don't run away just yet, it is not *that* bad.) Beware at not damaging the nearby PCMs.
3. Now using hot glue (hey, come back!), you can maintain in place the new screen in the frame of the old one. You can also glue the inverter board:
4. You now get a replacement screen module for a Portable 486c!
I installed it in the computer. It fits just right (obviously, it is the correct frame...) and now I can get rid of the external screen. The computer is at least somewhat portable:
Obviously, I need to find a way of hiding the control board inside the computer and do a proper connection on the *inside* of the computer. My plan is to hide the board behind the screen (since the new one is significantly thinner than the original) and use a ribbon cable and proper connectors that fits through the opening on the inside of the case to connect the graphic card to the LCD screen. I will also need to find a 5V line big enough to support the screen but I guess the old inverter board should provide this (on its input!!!). I think this plan will work, and I will update on its status if you guys are interested.
Final remarks:
- The only thing that bothers me it that I will have to install a new connector on the graphic card and solder the adequate connections. This is a very benign operation but I hope this won't cause any damage to the board. Or do you have any better idea?
- Also, I will need to change the keyboard cable, which is frayed. It should not be a big deal.
- One strange thing is that sometimes the new display is pixel-perfect (for example Windows 3.1 running in 640x480 or many games running in 320x240) but the basic text mode on MS-DOS is not. Does anyone understand why?
Cheers,
felixzero
This is neat! Nice computer and nice build. It's hard to come by these old computers in my end of the world (Hong Kong) so I usually have to pay an arm and a leg for them on ebay, but your restoration looks pretty clean. I'm restoring another two compaq's at the moment - the more common Portable III (286) and Portable 386 (both with retro orange gas plasma displays) - the limitation with these devices is that they are CGA only, so most games have to be run via an ISA VGA card on an external monitor. The goal is to remove the floppy and maybe install an internal battery to make them truly portable. Check it out here: http://www.vcfed.org/forum/showthread.php?66562-Restoring-Compaq-Portable-386
Nice work! The issue with the stock LCD panels are usually failed capacitors. The caps may have looked fine, but they were most certainly the issue and replacing them would have likely brought the LCD back to life.
Very nice. I found a similar panel to swap into a Compaq Portable III that fit perfectly. I also swapped out its guts (bought non-working off ePay) to make a portable Linux machine, but looks great running DOSBox:
attachment.php
attachment.php
Did you put a Raspberry Pi or something more powerful?
Thanks! They are also very rare in Europe! I looked for one also, even an out-of-order one, but nobody have them, and when they are sold, it is usually 300€+. Color screen and VGA graphics make the Portable 486 great for gaming while still being portable. And I added a Soundblaster clone in one of the ISA port. There is a jack to redirect the audio output back to the internal speaker. Very neat design.
Very probably, but there are about 20 of them, nearly all surface-mounted and of different values. I am not that patient!
The bad news is that the (brand new) screen started flickering then slowly turned white and won't show any image anymore :(
I think I might have put to much stress on the screen connector/cable with my temporary mount and I will check it. I hope the screen is not dead...
Resman..your LCD replacement looks great....anyway of sharing some info on the LCD. I, too have a Compaq III Portable (priginal gas plasma crt still works) but just making sure i have spare. Thanks
I put an NVIDIA Jetson inside. Much more powerful than a RPi yet still leaves a lot of room for additional adapters and power supplies.
It is a 1366x768 panel with one of those generic controller boards that support VGA and HDMI. I bought it for another project that didn't pan out but just happened to fit the Portable III almost to a T. The bigger issue would be the placement of the controller board and power supply.
Here is the album of additional pictures: http://www.vcfed.org/forum/album.php?albumid=313
Hello everyone,
Here is a quick update on the advancement of the screen replacement project. (Sorry for the terrible photos. This week-end the weather was bad, and my phone camera works poorly in low light conditions).
About the non-working system: turned out the new (old stock) screen was indeed faulty and died due to the stress of heavy use during one week. Since I cut a corner, I couldn't possible ask for a eBay refund... Anyway, I bought another one, and this time I kept it intact inside the Compaq and cut an extra corner of the frame instead. The screen is now held with 2 screws, but it is more than enough to keep it stable: the frame just fit and cannot move already, even before putting any screw.
Now, to make the electrical connection... Turns out the LCD controller board is slightly too thick to fit behind the screen. Instead, I keep it inside the computer, next to the VGA card. At first, I connect the bare minimum to carry out a VGA signal: red, green, blue, VSync, HSync and GND:
The original inverter board provides a 12V supply with enough amperage for a screen (hopefully!!!) and I got it across this capacitor:
Once everything in place, it is totally invisible from the screen side. On the inside, the extra board takes the room of one of the ISA socket. Not so great, but for the moment it will suffice:
And yes, after reassembling completely, it works:
However/Next steps:
- The image is affected by some interference. The OSD from the controller is not. So the issue is the VGA link between the graphic card and the screen controller. I plan to re-do it with proper return paths from the R, G and B channels.
- I don't like the idea of this new board showing when the computer case is open. I may desolder the bulky connectors to try to make it fit anyway. Let's hide all modern electronics!
Hello everyone,
Here is the final update about this screen replacement project. I made some significant changes as I was not too happy with having the LCD controller board inside the computer, next to the video card and motherboard.
As I explained last week, the board is too thick to slide between the screen and the computer case. This can be solved by applying the following mods to the board:
- I removed the VGA connector and replaced it with a small connector for ribbon cables (there was an empty room for such a connector on the PCB).
- Using a Dremel, I cut the power connector to remove the excess height.
- I replaced the biggest capacitor (used for filtering the power supply input) with one I could install sideways.
This way, everything sits nicely on the back of the screen. Here is a picture of the fully assembled screen module:
On the graphic card, I only had to add a corresponding connector to have a VGA connector inside the case. This only required minimal soldering (and could easily be removed -- these boards can be hard to find, I don't want to damage it.)
So, finally, this computer is back in business, ready to kick some asses, I mean, play DOS video games. From the outside, the mod is impossible to see:
However, that was much trickier to do than I first expected. I would still recommend trying to find the actual screen model over this kind of replacement if you want to have a working computer quickly. This is fun, but not quite practical!
Finally, my final step will be to replace the keyboard cable (which is frayed), by a new PS/2 cable. Also, it's not critical, but my computer is missing the little plastic keyboard feet. The ones that should go here:
I am thinking of replacing them by 3D-printed parts. If anyone has a Portable 486, I would appreciate if you could you provide some high resolution pictures (ideally on different angles) so that I can try to model them.
Cheers,
felixzero
Did you have issues with signal interference at all? I did when merely using the 12-pin header on my controller board vs the onboard 15-pin port. (3 pins are never used for VGA) And that's just a tiny 6" un-shielded length of cable.
Cheers,
felixzero
Hi felixzero,
I recently got such a machine myself and it still has *one* foot. :) I tried to get it off the keyboard when I had it open for cleaning, but the two plastic stems were too long for me to be able to slide the foot out without risking snapping something off.
If you are still interested in 3D printing the part, I'd be happy to help with pictures and measurements as needed. I took some pictures with my phone at https://photos.app.goo.gl/toLDUWEMEZJbHQWJ9, but they are probably not that useful. If you end up being successful in building a replacement, I'd ask if you can print and ship another one at cost for me, too. :)
Cheers
mikerofone
I'm working on some prototypes, had the same problem.
This version, the axis are too short. Next one will also have that middle edge. Thanks for those pictures!
Next version:
Happy to help! Let me know if any more pictures would be useful.
I wonder what the trick is for removing the feet without ruining anything. They must have come on originally in some way, so I assume there must also be a way to get them off again?
I should really get myself a 3D printer. :)
When I pushed my 3d printed versions in, I understood why so many 486's are missing their feet. There is a lot of tension on it.
I would leave the original in, I think that removing it will destroy it.
Ok, another update.
The last version was a bit hard to get in (the axis was too long), so 1 broke. The other feet I sanded the axis and one axis also at an angle. Then it clicked into place and because the 'at an angle' sanded side of the axis is not used when using the feet.
As you can see the feet perfectly align with the table surface.
so the next version will be:
So installation would be, insert normal axis first and the press down on the other. (feet has to be in the position as if it's closed.)
When I get these back from the 3d printer and they work, I'll post the STL file here.
Awesome, thank you very much for sharing! :) Just to confirm: The left foot is the one on the side where the ESC key is (and the logo on the bottom of the keyboard), and the right one goes below the numpad?
Cheers
mikerofone
