I'm finally getting around to trying out my RLV11 controller (M8013 + M8014) in my PDP-11/23, but as usual am not having any luck!
I first tried it without changing the address switch settings, just in case I was lucky and they were set to the defaults. Running the diagnostic gave me this:
After that, I pulled the 8014 and made sure the switch settings matched the documentation, which should be the factory settings, and are the diagnostic program's defaults. I also double checked the switches with my multimeter just in case they were bad (like my old memory board), but they tested fine.
Running the diagnostic with the supposedly factory default settings gave me different errors:
To me, it looks like the first run was more correct, as the second run seems to say it can't find the controller at all, though I'm not sure. I know I have the switches set to the factory settings as described in the manual, which should put it at 174400.
I'm not sure where to proceed right now... Anyone have any ideas? Thanks!
.R VRLAC0
VRLAC0.BIN
DRSSM-G2
CVRLA-C-0
CVRLAC RLV11 RL01 DSKLESS DIAGNOSTIC
UNIT IS RLV11
RSTRT ADR 145702
DR>START
CHANGE HW (L) ?
NO DEFAULT
CHANGE HW (L) ? Y
# UNITS (D) ? 1
UNIT 0
11/23 PROCESSOR (L) Y ?
BUS ADDRESS (O) 174400 ?
VECTOR (O) 160 ?
DRIVE (O) 0 ?
BR LEVEL (O) 5 ?
CHANGE SW (L) ? Y
DROP ON ERROR LIMIT (L) N ?
AUTOSIZE (L) N ?
CVRLA DVC FTL ERR 00113 ON UNIT 00 TST 009 SUB 000 PC: 020052
BUS RESET DID NOT CLEAR RLCS
CONTROLLER: 174400 DRIVE: 0
EXP'D: 000200 REC'D: 177776
CVRLA DVC FTL ERR 00114 ON UNIT 00 TST 010 SUB 000 PC: 020124
BUS RESET DID NOT CLEAR RLBA
EXP'D: 000000 REC'D: 177777
CVRLA DVC FTL ERR 00115 ON UNIT 00 TST 011 SUB 000 PC: 020162
BUS RESET DID NOT CLEAR RLDA
CVRLA DVC FTL ERR 00013 ON UNIT 00 TST 021 SUB 000 PC: 021446
CVRLA DVC FTL ERR 00014 ON UNIT 00 TST 022 SUB 000 PC: 021520
CVRLA DVC FTL ERR 00015 ON UNIT 00 TST 023 SUB 000 PC: 021556
030377
.R VRLAC0
VRLAC0.BIN
DRSSM-G2
CVRLA-C-0
UNIT IS RLV11
RSTRT ADR 145702
DR>START
CHANGE HW (L) ? Y
# UNITS (D) ? 1
UNIT 0
VECTOR (O) 160 ?
DRIVE (O) 0 ?
BR LEVEL (O) 5 ?
CHANGE SW (L) ? N
CVRLA SYS FTL ERR 00000 ON UNIT 00 TST 001 SUB 000 PC: 017066
CAN NOT ADDRESS RLCS
CVRLA SYS FTL ERR 00001 ON UNIT 00 TST 002 SUB 000 PC: 017164
CAN NOT ADDRESS RLBA
CVRLA SYS FTL ERR 00002 ON UNIT 00 TST 003 SUB 000 PC: 017262
CAN NOT ADDRESS RLDA
CVRLA SYS FTL ERR 00003 ON UNIT 00 TST 004 SUB 000 PC: 017360
CAN NOT ADDRESS RLMP
CVRLA SYS FTL ERR 00100 ON UNIT 00 TST 005 SUB 000 PC: 017454
CVRLA SYS FTL ERR 00101 ON UNIT 00 TST 006 SUB 000 PC: 017550
CVRLA SYS FTL ERR 00102 ON UNIT 00 TST 007 SUB 000 PC: 017644
CVRLA SYS FTL ERR 00103 ON UNIT 00 TST 008 SUB 000 PC: 017740
ILL INTER 004
PC 017770 PS 000341
ILL INTER 004
PC 014460 PS 000005
DR>
