booboo
I salvaged a non-working Sanyo VM-4509 9" monochrome monitor, very nice for the Apple II line. It came in parts, fully disassembled. It's working(ish) in that it has a good power circuit, tube, case, etc. However I get really bad video that is not adjustable with the horizontal adjustments.
After investigating, it turns out that the horizontal coil (variable inductor) is physically damaged. The metal square can (10mm on sides) is missing, as is the screw. The ferrite is broken and missing about 1/3 of the body. The ferrite turns and I can get it to display an image, but it's terrible with triplicate content.
The signal coming out post inductor is way off, showing 19.9Khz on what I would expect close to 15.6Khz.
*THE ASK*
If someone has the same monitor, I need markings and (wishful thinking) some measurements of the H between posts. I can measure the broken one but the readings are unlikely to be correct.
Here's a picture of the current inductor, PCB location is L601. The documentation shows it as Sanyo replacement number 4273106170, which I cannot locate.
Any guidance greatly appreciated.
Oh, and the inductor is a 5 post kind, 3 posts on one side, 2 on the other.
*THE ASK*
