daver2
10k Member
I shall have a look tomorrow. I am unable to access file sharing websites from work and my wife has an 'evening activity out' planned for me tonight!
All the binary files are named as Tektronix part numbers. They all appear to differ from those in my service manual, but the LABELS.TXT documentation on the locations seems to suggest that all the binary files are there. Huge relief for me not having to carry the burden of trying to extract the ROM contents and now I have insurance if my only good set of ROMs go bad.
face it guys
THAY MÀN HÌNH SAMSUNG J7 PRIME
For the upcoming VCFe in Zurich / Switzerland (18/19 Nov ) I repaired my TEK4052, which is now up and running ( no usable tapes yet...)
I wonder if that helps with a comatose system...I also dumped the contents of both 2716's onboard the diagnostic rom pack. ( also containg a 6810 )
Too bad I can't lug my 4052 across the border...I have (untested) spare boards if anyone in the neighboorhood wants to try some boardswapping...
Hi Jos,Hi Roland,
These firmware are mask-programmed. But are you are sure that the microcode PROMS are OK ?
Yeah, I'm aware of that from tapes in general. The smaller cartridges used in the HP-85 are particularly bad. I do move them by hand from time to time and then retension them in a generic QIC drive (which can't read them), but I have observed residue on the tape surface which is probably the result of the 30+ years of storage before I got them. I think I tried replacing the belts with ones from newer cartridges, but that didn't help, because the tape itself is sticky, probably from hydrolysis (a nasty problem that particularly renders videotape unplayable).Be carefull with the original tapes : the (white) drive belts on these are sticky and will destroy your tape if you just try them.
That's what I figured; Tek apparently did its own thing whenver it can. Look at all the custom chips in their scopes. On the other hand, apart from the ROMs and PLAs, most of the components in the 4050 line are fortunately off-the-shelf.The format, according to cctalk wisdom, is not compatible with anything else. Still have to organize some good tapes.
Micro-update: Jos' V5.1 firmware dumps are actually identical to those from my rev9 MAS ROMs. (
79F3 5F ; CLRB
79F4 20 ED ; BRA 0xED (relative = backwards).
3EC0 : FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF => ................
3ED0 : FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF => ................
3EE0 : FF FF FF FF FF FF FF FF FF FF DF FF 86 FF 12 7E => .........._....~
3EF0 : 79 F3 79 B2 79 C7 97 ED 5B A2 BB F4 F1 F6 79 F3 => ysy2yG.m[";tqvys
3F00 : FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF => ................
3F10 : FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF => ................
3F20 : FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF => ................
3F30 : FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF => ................
3F40 : FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF => ................
3F50 : FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF => ................
3F60 : FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF => ................
3F70 : FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF => ................
3F80 : FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF => ................
3F90 : FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF => ................
3FA0 : FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF => ................
3FB0 : FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF => ................
3FC0 : FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF => ................
3FD0 : FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF => ................
3FE0 : FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF => ................
3FF0 : FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF => ................
