This is on my ST251-1 that I thought was OK, but it seems to be getting worse and worse. I know it is probably on the way out, but could it have anything to do with the way it is setup in the Bios? I am unsure of a few of the settings. Cylinders:820, SEC:17 HEADS:6 those I think are correct. The precomp I have seen 65xxxx which doesn't fit or -1, or 0. That one I am unsure of. The LZ: is it 820 or 910 or?? '
If those aren't at the root of the drive getting worse and worse. Is there a DOS utility that runs on a 286 that might try and fix the FAT error? and other errors.
Thanks
Russ
Thanks
Russ
