Hi all,
I am working on a PET 4032. Wondering if you could help with the above issue.
Video of screen wobble:
(looks even more severe in person).
Board is a universal board, -03 marked (pg. 3 onwards). CRT board appears to match pg. 41
https://www.zimmers.net/anonftp/pub...4000_Series_4016-4032_Technical_Reference.pdf
I've done the basic checks, transformer voltages all as expected, DC mainboard voltages all as expected.
CRT board: DC (i.e. rectifier) in to regulator shows ~2V peak-to-peak, but totally smooth 17.98V on the output of the regulator.
CRT board checks: all test points match the waveforms in the service manual (pp. 42-51).
Suspected transformer (US import to UK, using step-down at 50 Hz), but operation when open shows same wobble with no discernible change.
Does anyone have any suggestions on where I should look next (or what I should double check)?
Thanks,
Jason
Thanks,
Jason
