SDL2TRS in Linux
tezza
New Zealand
I've been exploring Linux over the past few months. As a learning exercise I decided to have a go at installing SDL2TRS in a couple of my VirtualBox Linux environments. Using the .deb file on offer, I managed to install it no problem in Linux Mint 20.2. (see photo). The emulator seems to work fine apart from jerky sound.
On Arch Linux it was a different story. I had all the dependences installed and compiled the AUR-supplied PKGBUILD but no go. I suspect some of the updated dependencies were not backward compatible with what was required. Anyway, it was fun, a good way to learn about Linux and something different from my go-to trs80gp and TRS32 emulators in Windows.
Tez
  • Like
Reactions: ACK
There are tutorials for on the Debian forum for:
DosBox is needed for some of the TRS-80 Emulators.
1. DOSBox https://forums.debian.net/viewtopic.php?f=16&t=61888
2. SDLTRS https://forums.debian.net/viewtopic.php?f=16&t=67657
There is an updated SDLTRS package that I have somewhere, but will have to look for it.
3. Z80 Emulator https://forums.debian.net/viewtopic.php?f=16&t=66644
4. XTRS by Tim Mann https://forums.debian.net/viewtopic.php?f=16&t=61891
5. TRS80 by David Keil https://forums.debian.net/viewtopic.php?f=16&t=61890
6. TRS80GP by George Phillips Runs fine in Debian under WINE. I have the Model 1, 2, 3, and 4 running.
wine trs80gp.exe -m1 -d0 td28rs2.dmk
wine trs80gp.exe -m2 -frehd -d0 l2-631ss.imd
wine trs80gp.exe -m3 -d0 ND80M3-3.DSK -d2 imd-DS
wine trs80gp.exe -m4 -d0 MMCPM231.DSK
TRSTOOLS also runs fine on Debian 11 - 64 Bit under Crossover (21.0.0) by Codeweavers. I have the following command:
"/home/larry/.cxoffice/TRSTools/desktopdata/cxmenu/Desktop.C^5E3A_users_crossover_Desktop/trstools.lnk" %u
in the Launcher.
That should get you running whatever you want. Similar Tutorials are on the OLD Ubuntu Forums.
Larry
  • Like
Reactions: ACK
Thanks Larry. I'll stick to just SDL2TRS on this Linux platform. Windows is still my most used OS and those other emulators work just fine there. I won't bother installing them in the Linux environment as well. SDL2TRS (derived from XTRS) was exclusively Linux though, so I thought I'd give it a go.
Tez
  • Like
Reactions: ACK
  • Like
Reactions: ACK
Just a note that trs80gp has had a native linux version for a little while (and MacOS and Raspberry Pi).
SDL2TRS is Free- AND Open-Source Software (BSD-2 License): you can just compile it for other machine architectures (like SPARC64) ... system requirements are also very low: it runs on a Pentium II with 300 MHz ...
  • Like
Reactions: ACK
Hi, you could try to adjust the "Cassette Default Sample Rate" (ALT-T key): current XTRS uses 11025 instead of 44100 for sound ...
  • Like
Reactions: ACK
  • Like
Reactions: ACK
One thing I'm confused about is how to select the EACA models. They don't show up in the config menu? Only the TRS-80 ones?
Seems that my eMail didn't reach you ... the EACA models are just "extended TRS-80 Model I"-clones for SDL(2)TRS: just load the ROM for the EACA/TCS machine in Model I-mode (the default) and the emulator should auto-detect the system (EACA EG 3200 "Genie III" or TCS Genie IIIs) ... some systems (LNW80, TCS SpeedMaster/Genie IIs) must be selected in the "Emulator Settings" as "Speedup Kit" ...
  • Like
Reactions: ACK
Thanks. Yes, your letter was sitting in my SPAM folder for some reason. I just found it. Thanks for the zips (and that information). I might try installing on Arch Linux again. I didn't use yay. I Installed git and used it to clone sdl2trs 1.2.21-1 from the AUR repository. Then used $ makepkg --syncdeps to build the package. I had a permissions issue first which I seem to solve and the final error was "sdltrs FATAL ERROR: failed to initialize SDL: Failed loading udev_device_get_action: /usr/lib/libSDL2-2.0.so.0: undefined symbol: _udev_device_get_action". I'm sure all the dependences were installed. Mind you, I'm a novice at Linux so there is a good chance I missed something. Arch-Linux is unforgiving. I'll try it with yay at some stage. Meanwhile, thanks for working on the emulator. Seems to work fine!
  • Like
Reactions: ACK
tezza,
Is telling you that a library is not installed.
In Debian 11 it would be:
sudo apt install git libsdl2-dev libreadline-dev
Earlier version of Debian would be:
sudo apt-get install git libsdl2-dev libreadline-dev
Other Linux Distro's use different package managers.
Larry
  • Like
Reactions: ACK
SDL2 can use udev on Linux to support devices like Joysticks: seems there is some breakage, maybe libudev is not installed or outdated. On Arch-Linux "sudo pacman -Syu" for full system upgrade sometimes solves such issues ... or introduces new ones ... ;)
Arch-Linux is "bleeding edge" ... and sometimes this hurts ... ;)
Providing software packages for various Linux distributions is very little fun, so I'm grateful that Tércio Martins (from Brazil?) maintains the AUR packages of SDL(2)TRS ... :)
Thanks! Please let me know if there are any questions, issues or requests ... :)
  • Like
Reactions: ACK
tezza,
Larry
Hi Larry,
Possibly. It's also possible that Arch Linux updates have broken something. As Jenz says, being on the bleeding edge can often do this. Anyway, while I have dabbled with Arch Linux, I've decided I don't like living with a rolling distro which requires so much hands-on management. Yesterday for some unexplained reason, my Arch Linux kernel failed to load and I had to get things back using a live installer for repair. I'm happy with Linux Mint and will stick with that as my main Linux platform for now.
Tez
  • Like
Reactions: ACK
I substituted my System 80 blue label ROM for the usual TRS-80 ROM. As you would know the ROM has a small difference in the way it handles cassette functionality. I'm pleased to report that I could read/write BASIC CAS files just fine and these CAS files could also be read in other TRS-80 emulators. Also, a BASIC music program for the System 80, that normally has to be tweaked to run on the TRS-80 M1 ROM (as it uses the cassette port) also worked just fine. The "extensions" in the System 80 ROM, like the lower case driver, also seemed to work, although I didn't test all the functionality of that 1.5k ROM extension.
So well done on getting the emulator to seamlessly deal with these small differences.
I enjoyed the stringy floppy capability. My virtual wafers loaded just fine.
  • Like
Reactions: ACK
The System 80 blue label ROM is identical with the HT-1080Z ROM (Hungary) and the Dismac 8001 (Brazil). The System 80 Mark II/Educator seems similar to the TCS Genie II, but the ROM is different. The F1 - F4 keys of both models are supported, so you can run (and use) WORP-9 with the System 80 MK-II ROM in SDL(2)TRS. Support for the UART ports of the System 80 was added in SDL(2)TRS version 1.2.18, so connecting to a real machine using the serial device port in Linux should work in theory ...
  • Like
Reactions: ACK
[BASIC CAS files] So well done on getting the emulator to seamlessly deal with these small differences.
These features come from XTRS, so kudos goes there! :) Alan "EtchedPixels" Cox wrote the emulation of memory expansions ("Dave Hufman", SuperMem, HyperMem, Selector) and the Lowe LE-18 HRG card back in 2018 for XTRS: https://github.com/EtchedPixels/xtrs ...
The "Selector" is compatible with LNW80 CP/M: with the support of the extended HRG (480*192 pixels) in SDL(2)TRS and the options "-speedup lnw80" and "-selector" you can enjoy CP/M in 80*24 graphics screen mode:
  • Like
Reactions: ACK
Not even nearly that much. When I first packaged xtrs for Debian, my development box was an AMD "5x86"--a 486 clone clocked at 133 MHz. :D
  • Like
Reactions: ACK
The IBM Thinkpad 600 (Pentium II 300 MHz and 256 MB), running Debian 2.2, was just ready to use here ... ;) I've also done some testing on a Pentium 75 (comparable to the AMD "5X86"): usable, but sound output via ISA card caused some games to "stutter" ... SDL(2)TRS still supports the old SDL 1.2 lib and 8 bit color depth, so running it on 800*600 screen resolution with 256 colors is possible ...
BTW: an official Debian-package maintainer for SDL(2)TRS would be really great... :)
  • Like
Reactions: ACK
