Searching for Inspiron 8000 replacement hinge
ikethederg
Just got this Dell Inspiron 8000 for cheap, but the hinge was snapped. Definitely can't be fixed with epoxy, had another machine where hinge broke like this a PowerBook g3 Lombard, and tried with epoxy and snapped first time. I can't seem to find a replacement.
I'd throw an offer to this listing, might be able to snag the whole machine with shipping for 25 bux... Uses exact same hinges and other parts.
I found a c800 for around the same price with a few more parts, which is an even more similar machine, same board, GPU, etc
I think that is your best bet, using a donor machine. I found some new hinges on other part sites but they want a fortune.
I found a c800, hinges are better but are very loose, not broken completely but like when apart the hinges pull out of like zamak case of the hinge. Could be fixed with epoxy I read.
Loose can be fixed with some vice grips and a few mins of free time! Be patient, just a 16/th of a turn at a time with some needle nose.
I hate buying a whole machine just for hinges (did that with a ThinkPad R40 years ago), but it's cheaper and you get other parts.
