glitch
Wow, imgur says *five* *years* ago I pulled out Amy's Indigo2 IMPACT machine and started cleaning it up:
This machine came from Virginia Tech surplus, pretty sure Amy picked it up while we were still in college. Someone helpfully wrote a bunch of information down and stuck it inside the front door:
Including the hostname and the date it was shut down (which makes sense for when we were still at VT):
Well, last weekend I finally decided to actually set it up properly. I'd already done the NVRAM, of course I believe I'd had NetBSD 7.x booting on it, which let me verify everything was still working. Interestingly, NetBSD 9.2 no longer seems to boot from the installation CD: it loads the kernel and stops when it identifies int0. No messages, just hangs. Something to investigate later!
The main impetus to actually getting IRIX 6.5 installed was a) getting a hard disk in it and b) remembering to burn a set of discs. I have a super nice Seagate Barracuda with 50-pin low density connector, 36 GB, 0.2 hour on the internal counter. Very quiet, doesn't run hot. Since the Indigo2 should be fast enough that a SCSI2SD would be the bottleneck, that's where the Barracuda is now installed. I couldn't get a SCA drive and adapter in there, at least not with what I thought was a suitable fit, and I was worried about heat anyway.
After feeding discs and waiting a while, I have IRIX 6.5 up and running:
I had images for IRIX 6.5 from 1998 so that's what I've burned, but I'm thinking I will do a clean install with the 6.5.22 overlays, since I know everything is working now.
First thing to update will obviously be the RAM: it has 64MB installed, and if I understand the tables correctly, I should be able to put 384MB in there, with the R4400.
