G'day,
I have a Sinclair Spectrum 48k which I have ALMOST repaired. I have changed CAPS, replaced Video Ram and it boots diagnostic ROM, but in black and white, passes first RAM test then fails on all subsequent tests. I have pinned it down to the 12v being generated by the DC-DC circuit. It is measuring 10.3V at video ram, -5 and +5 are good. If I remove the 4116 ram the voltage goes back up to 12v and the screen displays Colour. I have replace the TR4 and TR5 but they are aliexpress sourced, so I am wondering if they could be dodgy. I have heaps of tested 4116 ram and tried 3 different batches, same issue.
Does anyone know what voltage i should see on the output of the coil?
I have measured the resistance and they seem okay, no shorts and continuity on each coil, but could the coil be failing under load give me such an issue?
Anyone experience similar issues?
Thanks....
Paul in Victoria Australia
Thanks....
