As I said before, I have a Gateway P5-120 Motherboard. It is the OEM version of the Intel Advanced/ZP Zappa Motherboard. It uses an AT Power Supply, and if you want to use 3.3v PCI Cards, you need a power supply with the 3.3v AUX Connector. I have left this disconnected and not had any issues with any cards except a radeon 9200. For the record, Gateway left it disconnected as well. It has a Pentium 200 in it running at 133Mhz, because thats all the board supports. It is maxed out with 128MB of EDO RAM. Supports booting from CD. Baby AT Form Factor, but has two PS/2 Ports where the big DIN port usually is. It has Two COM port Headers, 1 parallel header, you should have the cabling for that already. Intel Zappa. Rappa tappa tapppa for the intel zappa. If youre interested in buying the the zappa zappa zappa, let me know
