twistedpneumatic
Would it be possible on a 486 laptop to solder in a sound card. Like if someone made an OPL3 daughterboard with breakout pads and soldered very thin wires to each of the IRQ, Data and Address lines. Either that, or some kind of internally soldered OPL to LPT adapter with a switch and a built in amp/speaker?
This machine is a 486DX4/75Mhz so there is plenty if CPU cycles to work with.
