tezza
When I first started playing around with vintage tech I used to think socketed chips were great. You could swap suspected faulty chips in and out and enable a repair easily.
Now I've come to the conclusion that it kinda depends on the socket. In a few of my vintage models (Commodore Pet, Apple II+) it has been the sockets that have caused the problem in the first place!
I've just diagnosed a fault on my spare Apple II+ board. The board appeared dead. One clue was a TTL chip servicing both the keyboard and RAM was getting very hot. Investigating this I discovered it was not a short in the chip itself. Rather the OUPUT of a gate was indicating -3.5 volts when the inputs were positive (err...at least one was, the other was -0.75...but only with the chip in place. The true input (if the chip was removed) was positive).
Anyway, this gate output was connected to pin 2 of a RAM chip. What was happening was there was a short across pins 1 and 2 in the RAM chip socket. Not underneath the socket, or in the RAM chip, but somewhere IN THE SOCKET. This short occurred ONLY WHEN a RAM chip was inserted and pressed down securely. Pin 1 carried -5 volts. Being shorted to pin 2, high negative voltage then appeared on the output of the gate, thereby cooking the logic chip.
It took me a while to figure it out. I still don't get video even though the socket, RAM chip and cooked chip have been replaced. Something else has probably been fried from high -ve voltage being where it shouldn't be.
Anyway, the moral of the story is faulty socket issues are common in some systems and can be hard to track down.
Tez
Tez
