Something to create a cp/m disk
Extracting a CP/M disk image out to the floppy disk is pretty straightforward. Usually you'll start out with an image file on the hard drive, containing a copy of the Osborne bootdisk, which must be extracted with whatever program created the image. You'll also need a program that changes your PC's floppy parameters so that it will be able to write the CP/M format of your choice. One very commonly used program is 22Disk, which is available d/l from Gaby's site:
http://www.gaby.de/edownl.htm
--T
--T
Thanks Terry.
I cant seem to find a image for the disk, i downloaded teledisk, but the osborne 1 images wont boot, and I read somewhere this isn't a problem, I als tried the B: drive with the shift " thing, and the drives aren't the issue.
Terry, would you happen to know where I can find some images of osborne executive disks?
alexkerhead wrote:
> Thanks Terry.
Did you try contacting Gaby Chaudry?
She's a wonderful lady & I'm quite sure she'd be happy to help
anyway she can. Unfortunately the only person I knew of (Don
Maslin) who would have had an image (or would have provided a
system disk for your Osborne Executive) passed away 2004. If
anyone knows what's happening in this regard - that'll be
Gaby.
Suprised an Osbourne 1 system disk wouldn't work on an
Executive though, the machines simply look alike! Must be in
the hardware where the incompatabilities start.
But yeah, try Gaby (if you haven't done so) cause she'll be
very happy to help. Her e-mail is gaby at gaby dot de
Cheers,
CP/M User.
CP/M User said:
alexkerhead wrote:
> Thanks Terry.
Gaby.
Cheers,
CP/M User.
I didn't know Don Maslin passed away.. Everywhere i have been(search engines) that mentions his work said nohing about that(old links probably ..That is sure a great loss.
I will contact Gaby, hopefully she will have some good advice for the situation.
Thanks.
edit: btw, the osborne 1 and executive are quite different in appearance.
Osborne Portable I
Osborne Executive
Oh yeah, sorry 'bout that!
Cheers.
No need to apologize.
I think the only difference besides physical, is that the ROM has a different programming, but the internals are pretty much the same.
Unfortunatly, the executive sold far far far less units then the portable I, reason is that by the time it was made, the ibm compatible were hitting hard, and they announced a pc compatible to be released soon, so sales dropped exponentially. So the Executive is one of the rarer osborne models, sells for more then the osborne I. But yes, it corrected all flaws of the osborne I, the screen was an excellent upgrade, but is still small. I cannot understand how anyone used these day to day...lol....The words are soooo tiny.
I've got an issue of Popular Computing around here somewhere, and the cover story is about Osborne 'jumping on the IBM bandwagon' with the introduction of the 'Executive II', which is CP/M & IBM compatible. I'll see if I can find it...
--T
