It's done! A single physical machine that can run everything from DOS all the way through modern Windows, with full function for each operating system. I am fully loaded with DOS, Windows 3.11, and Windows 7 so far with more to add in between. The goal was to build a multi-boot wonder, one that didn’t need to swap out hardware components between booting-up each OS. Ostensibly a first?
Here is the final build breakdown:
CASE: Raidmax Smilodon ATX-612WB Black/Silver Foldout Computer Case
RAM: 4GB RAM (4 1GB Sticks)
HDD DRIVE #1: 240GB SATA SSD (SATA MOB Connected in Combined IDE mode)
HDD DRIVE #2: 80GB IDE (driven off of the IOFLEX Ultra)
MAIN BOARD: SuperMicro P4SCA Intel E7210 Socket 478 800MHz F/S Bus
CPU: Intel Pentium 4 Prescott 3.4GHz Extreme Edition/1MB Cache
CPU Cooler: GlacialTech Igloo 4360 Plus Intel 478 Cooling Fan
PSU: Logisys Corp. 480W 240-Pin Black Beauty ATX 20+4 PS480D-BK
EXPANSION SLOTS: 3 ISA ports and 4 PCI ports
SERIAL PORTS: 2 Fast UART 16550 serial ports
PARALLEL PORT: 1 ECP / EEP Parallel Port
ONBOARD HD PORTS: Dual Headed IDE (4 IDE drives), Floppy, 2 SATA
Expansion IDE PORTS: IOFLEX Ultra ATA PCI RAID Controller
USB 1: Two external USB 2.0 Ports
USB 2: StarTech.com 7 Port PCI USB 2.0 Card Adapter PCIUSB7
FLOPPY 1: Internal 3.5" 1.44MB
FLOPPY 2: Internal 5.25" 1.2MB
REMOVABLE STORAGE: Internal 100MB IOMega IDE Zip Drive
CD/DVD DRIVE 1 DVD/CD IDE Rewritable Drive
CD/DVD DRIVE 2 DVD/CD SATA Rewritable Drive (in combined IDE mode)
VIDEO ADAPTER 1: ATI RageXL 8MB PCI Graphic Controller (On board/disabled)
VIDEO ADAPTER 2: EVGA 6 GeForce 6200 DirectX 9 512MB 64-Bit DDR2 PCI 2.1
NETWORK ADAPTER: Intel® 82541 10/1000 Gigabit Ethernet Controller (On Board)
WIRELESS NETWORK: TP-LINK TL-WR702N Wireless N150 Nano Router in Client Mode – USB Powered
MODEML: US Robotics 56K Internal Modem
SOUND CARD 1: Yamaha Audician 32 Plus (ISA) w/ DreamBlaster Synth S1 General MIDI
SOUND CARD 2: SoundBlaster PCI
USB CARD READER: Internal USB Card Reader
SPEAKER: SONY Deep Base Amplified Speaker
KEYBOARD: Classic IBM Model M Keyboard
MOUSE: PS/2 Mouse
MONITOR: 20" LED Display
MOUSE: PS/2 Mouse
