lockwood77
- Joined
- Jun 9, 2025
- Messages
- 4
Hi all. I've got a 48k ZX Spectrum that boots with the image you can see here. I've done all the pre- and post-power tests including lower memory described from here: https://www.lostretrotapes.com/zx-spectrum-repair/
All the figures from the multimeter read fine (certainly within the tolerances mentioned in the above guides). However, the screen looks very much like the lower memory IC6 failure (first 4116 RAM chip) shown on this page: https://spectrumforeveryone.com/features/quickly-diagnose-48k-ram-failures-ninja-style/
The voltages for that chip read fine though (-4.7V pin 1, 11.8V pin 8, 4.7V pin 9), as do all the other lower memory chips (very similar figures for each).
Before I go trying to change any 4116 chips, is it likely that one could fail whilst still reading the correct voltages? Could that screen of death represent the failure of anything else?
The regulator does read over 100 as per the pre-power test detailed in the first link above, but it takes a while to get there (well over 10 seconds), perhaps that's at fault and if so, would it cause the first 4116 to look like it's failing?
