ST-225 hard drive not being read by WD1002A-WX1 controller
Rubix
Hi all, I recently was very lucky to having been given this early PC's Limited Turbo PC from 1985. This was the very first Dell PC.
I was able to boot it from floppy, using a different monitor. The monitor that came with it, gives a garbled image and I'm not sure if it's the monitor, or me using an incompatible cable. The monitor cable was missing when I got it.
The problem I'm facing now, is that I can't get the computer to read from the hard drive. The cables were disconnected when I first got it, and the controller cable was damaged. I connected a different controller cable which now seems to make the controller and drive initialize properly. The drive mechanically sounds as it should; it spins up properly, does the whole seek tests and then the LED turns off. Then a short blink. Once the POST is done, both drive A: and C: light up looking for a boot sector, but it doesn't find anything.
Booting to PC-DOS 2.0, I can go to C: but it can't read the drive. The light doesn't even come on. When I try to list the partitions with FDISK (option 4), I see the drive LED blink for a bit and then FDISK throws an error saying it can't read from the drive.
Interestingly, the exact same things happen when I disconnect the data cable entirely. I tried a different data cable, but that gives the same results.
I attached pictures of the controller with the jumper settings and the cable connections. The controller card's BIOS is the Super Bios.
Controller settings can be found here: https://stason.org/TULARC/pc/hard-d...L-CORPORATION-Two-MFM-ST506-412-driv-221.html
Hard drive specifications can be found here: https://stason.org/TULARC/pc/hard-drives-hdd/seagate/ST225-21MB-5-25-HH-MFM-ST412.html
I checked all the jumpers on the card, and it all seems correct. Does anyone have any suggestions what I could try next? Thank you!
unfortunately, the drive may have lost its low level formatting after (what I assume was) sitting in storage for a long period of time. if you're not trying to recover any data, I'd recommend attempting a low level format.
If there's some advice I trust, it's from an ST251 hard drive ;) Haha. I was considering performing a low-level format. I don't necessarily need to save old data that may be on the drive, but I am curious to see what's on there.
What do you think about the fact that disconnecting the data cable makes no difference at all in how the drive behaves?
in my experience, having no data cable connected would produce the same result as an unformatted drive.
what you can try to do before trying to format it (if you have the tools, etc.) is download a copy of SpeedStor (here: http://minuszerodegrees.net/software/speedstor.htm ) and run it on that PC and see if the non destructive tests pass (controller test, seek test, defect manager > scan surface ). If you try the surface scan and most, if not all of the sectors are reported as bad, don't be alarmed and run a low level format.
Thanks! I tried the low-level format, but it quits with error code 80. I still suspect there's something wrong with the data channel.
That results in error 20 (controller failure) when trying the low-level format.
ok so the controller is definitely doing its business. can you take a photo of the current jumper configuration, or is it unchanged from the photo in the first post?
also, try formatting with speedstor and see what it says
forgot one thing, how is the drive jumpered?
I changed the configuration back to what it was. I did try the jumper on pin 2&3 but that doesn't make a difference, so I changed it back to 1&2.
I think the drive is jumpered correctly. I think this indicates drive 1, right?
I want to try Speedstor but I'll need to prepare a more modern computer for that with which I can write to 360K floppy disks.
Alright, thank you so much for your help! I had a PII with a 360K disk drive that I used for this sort of work. I'm gonna dig it up!
No problem, it's just hard trying to do it without it in front of my face :p remote support isn't really my thing
I wouldn’t trust that the jumper configuration for the built in drive table matches the website in your first post. I’d recommend using dynamic. You could also run sstor /romlist to see what’s in the table on the card.
I wanted to post back here since I found the issue. I added an XT-SD card and that didn't work either. It turned out that the motherboard was configured for 4 floppy drives, rather than 2. That got in the way of the HDD ROM address I guess, or maybe it tried to read the HDD as if it were an FDD. Either way, setting those switches correctly fixed the issue. The controller and HDD were configured properly from the start.
