Some of you old time Model I users, what the heck is causing me some crazy strange issues with double density disks.
I am using calibrated drives, that are aligned right and the lobes and clamping are correct, and have tried freshly formatted disks using a Model III using the same drive on the Model I.
Single Density works correctly. Double Density is erratic as best. I get data record locked, HIT, Directory read errors, etc. This is more than one drive.
Drives are terminated right (Well I'll double check that its not in backwards). I cleaned the card edge, no difference. This just started.
I'm thinking it might be one of the two controllers going out on the doubler board, but not sure if anyone has any thoughts on if its a support chip dying.
LDOS 5.3.1 and yes, FDUBL (P) is being used.
