Glen M
I've asked in every other corner of the internet so may as well ask here too!
I've been working on a faulty socket 7 motherboard I picked up from eBay a while back. This was one of those late night I really don't want this but screw it I'll stick an offer on anyway purchases. The board had (has) damage from its previous life with several pins damaged on one IC, 1 capacitor was completely removed from its legs and a few traces were badly damaged (1 cut the others partly cut). All this has been repaired but the board refuses to boot, refuses to do anything actually.
This is everything I have tried so far.
- I've tried a post card is both the ISA and PCI slots. On power up the card reports all voltages are correct. The reset briefly lights then goes out (so reset is working) then clock and frame LEDs light. No activity on the IRQ light and no post codes.
- I've tried 3 different socket 7 CPUs all with the same result.
- Power measures correctly around the board where I have been able to test, i.e. were I've found data sheets for and know what pins are VCC/VSS etc. Just the chipset to test in this regard.
- CPU is getting the correct 3.3v and is seemingly running, it certainly get hot quickly if powered without a heatsink (only for a few seconds)
- BIOS seems good. I've read it out on my EEPROM reader and even written a new one I found online but no difference in behaviour. Comparing the 2 ROMS they seem identical.
With there being absolutely no signs of life I'm drawing to the conclusion that the board is just dead either from further damage I can't see, possibly internal damage or perhaps one of the main chipset ICs are dead. There is a slight twist or warp to the board which I have been told could be an indication of internal damage.
If its dead then so be it but I'd like to if possible know for sure that its just not something silly that I've missed. It seems to be a rare board in so much as finding information about it online is almost impossible. The board is labelled AVB55C Rev B2.
Any advice for what else to check?
