Tincanalley
This drive was working fine a day ago. I used it to boot 360K DOS disk to install a Hardcard. I even loaded files to the newly installed Hardcard from the drive off 360K floppies. Today I tried to install a game from 360K floppies and got a general drive read failure. I though the disk was bad, but when I tried any capacity other than 1.2, it failed. The second 1.2 drive works just fine with both capacities.
How does the drive know a 360K is in? I recently cleaned the heads and wonder if I messed something up in regards to disk identification. When I run IMD and test speed with a HD disk, it works just fine and displays speed. When I try the same test with a DD, it tries, but never determines speed and just drops back to previous menu. When I do the alignment test with a HD disk, it comes up error free on all tracks and heads. If I put in a DD, it has a question mark for track and can't perform test.
I've had this drive since '91 and never had an issue with it. Nothing has changed with the drive configuration, so it has to be something with the drive. Any suggestions where to look?
