If you are one of the three people still working on SunOS systems, you have likely tried to change libc to support DNS directly, vs. the default NIS support for name resolution. The Sun document SRDB ID: 3886 doesn't work correctly for 4.1.4 systems, and likely doesn't fully work for any system due to errors. The libc Y2K patch 102544-13 answers many questions, primarily that you need to fix xccs.multibyte.o, since ar truncates its name, and also add -ldl to the makefile so the libdl is linked correctly. Otherwise you'll get these build errors for most packages:
_dlopen
_dlclose
_dlsym
__mbstowcs_xccs
__mbtowc_xccs
__wcstombs_xccs
__wctomb_xccs
I've attached a text file with modified instructions.
Simon
_dlopen
_dlclose
_dlsym
__mbstowcs_xccs
__mbtowc_xccs
__wcstombs_xccs
__wctomb_xccs
Simon
