Hi guys,
i got a TA alphatronic pc and after a long way of failed tries i was able to connect it to a SCART tv using the composite port.
the computer works well and i'm thinking to make 3d print of the mising key.
As it is i can connect it to a tape and get software from that source, so i'll try to use the pc soundcard to play a wav of the tape, the issue is finding wav of software tapes for this machine online
The (major and real) issue i'm facing now is that i would like to use CP/M and it software base on disk, so i need the disk drives (5,25). I would like to adapt some gotek instead of real floppies but afaik
the F1 disk drive is the one containing the controller while the other is connected as a second unit to the controller included only in the F1 drive. So i think i'd need to emulate the controller
So my question, if anyone know this machine is:
1) is there a source for tape software for ta alphatronic pc to be downloaded as wave to send to a real tape or to the tape port of the computer?
2) is there a way to emulate floppies via some device as gotek or i'm forced to find a F1 real drive?
