Thank you for the advice, I will try to locate and replace the parts. I tried to turn the screw on the variable resistor in both directions and it don't make noticeable changes, only slows the motor a bit when reaching one end...
Did you do the service checks on page III of Sams Computerfacts yet? There's no use replacing parts if it's not the servo board that's the problem.
Apart from that, the drive reads fine the 360k disks written by itself or by the other Tandon 360k drive. So I declare it fixed.
Thanks for all your advice!
I would do a careful inspection of the capacitors on the drive motor board. I have had two where the caps leaked and had no idea until the drive started acting up. Spinning problems and then no spin at all. I have a thread there, somewhere, with pics. Even if the caps aren't leaking, they might be out of spec enough to cause an issue.Further testing has revealed this to be a false positive. Still having intermittent issues with maintaining rotational speed
I've already replaced them. Only things left are the LM2917 and the motor itselfI would do a careful inspection of the capacitors on the drive motor board. I have had two where the caps leaked and had no idea until the drive started acting up. Spinning problems and then no spin at all. I have a thread there, somewhere, with pics. Even if the caps aren't leaking, they might be out of spec enough to cause an issue.
