Eudimorphodon
@Eudimorphodon And I'm pointing out that there should be a way to get similar technology if desired, even if you ending needing a more sophisticated sensor that can detect colors.
Of course, you could just use some sort of modern touch overlay/touchpad or even make a break-beam setup based on IR, visible light lasers, etc if desired. Even magnets and the right sort of hall effect sensor would work on a LCD which isn't remotely as sensitive as a CRT to an electrogmagnetic field...
Unless you build something into to the LCD itself (maybe embed some kind of specialized "microdot" pixels that can refresh at a higher frequency and emit IR or soft UV specifically tuned to a matching light pen) anything along these lines is going to result in gross visual artifacts... and to what end? The reason the light pen was a popular technology in its day was it was cheap (just a photodiode and a bit of glue) and it worked on any CRT screen. In the modern world if you want a "pen" there are a *ton* of alternative solutions for getting an X/Y coordinate off a flat panel display that are cheap and completely agnostic to the display tech. You have touchscreen overlays (capacitive or resistive), both dirt cheap, which just require a sheet in front of the screen, there's EMR tech like used on Wacom (and knockoff) digitizer tablets... there are sonar-based systems for doing pens on large surfaces (I used to work in an office that had a thing that could digitize you drawing on a whiteboard; you just slipped a little collar over the pen and a couple of sensors flanking the board triangulated its location; similar things exist to stick on large TV sets), and for "light gun" applications where you want to be able to target things from a distance there's tech like the IR sensors used in Wii-motes. (Which, amusingly, is vaguely related in principle to how the heat seakers on the original Sidewinder air-to-air missile worked.)
An optical LCD light pen is a solution in search of a problem, and also not really on topic for vintage computing.
