twistedpneumatic
Does anyone know a source of batteries for the Tandy 1400LT. I know that amazon has the JST SM connectors so that isn't a problem. I have found the two following:
http://www.batteryspace.com/NiCd-Battery-Pack-12.0V-2200mAh-10xSc-for-Solar-Panel-/-Emergency.aspx (Is correct capacity but size seems a bit small)
http://www.batteryspace.com/nicdbatterypack12v3ahcx10forsolarpanelemergencylighting.aspx(Supposedly correct cell size but size seems a big big)
Are those compatible or at least able to work? I'll be able to 3D Print a size adapter if necessary.
