dkarguth
I am trying to restore a TRS-80 model II and have run into this problem.
(sorry about the garbage picture, the phone camera wouldn't cooperate with the CRT refresh rate)
When I power the system on, it displays this flickering screen with the message "Boot Error MF". I know that this means it has a memory fault, but I have tested all the RAM in the RAM card, and replaced the single faulty RAM chip with one from the other card. (it was a 32k system with another 32k card installed.)
I realize that the boot error could be due to an addressing problem, but the flickering is what has got me stumped.
So far I have done the following to the machine:
-Recapped the PSU, CRT driver board, backplane, and all the logic cards.
-Cleaned the card edges and connectors on all the cards and backplane
-Tested all the RAM chips, and replaced faulty chip
-Reseated all the DIP ICs
-Removed all the cards apart from the CPU, Video card and Memory card, and still get the error. (the error is the same when the memory card is removed)
-Rearranged the cards in the backplane
Nothing so far has helped at all with the issue, so at this point I'm stumped.
I'm new to TRS-80 systems, so I have very little knowledge of their common problems or failures. This machine is a particularly important one due to the low serial number, and I would like to see it restored and working.
Any help anyone can give is appreciated.
