nikola-wan
I just learned something from reviewing Micheal D. Cranford's update to his documentation for his 4051 FAST GRAPHICS ROM.
He stated:
ALL X,Y POSITIONS ARE IN GDU'S (0.128 DISPLAY RESOLUTION STEP SIZES).
COORDINATES ARE LIMITED TO THE DEFAULT DISPLAY: 0 TO 130 HORIZONTAL AND
0 to 100 VERTICAL (0 TO 1015 AND 0 TO 781 USABLE POINTS, RESPECTIVELY).
I was curious about these limits and wondered why not 0 to 1023 for the X-Axis since the Tektronix 4051 has a 10-bit DAC for X and Y.
So I wrote a test program for the 4051 EMULATOR to display bounding boxes for 0-100 for X and Y and 0-130 for X and 0-100 for Y and labels for 72 characters of text.
Here is the short program I wrote:
And the resulting screenshot from the 4051 EMULATOR configured for fine dot mode (single pixel) for TEXT and GRAPHICS:
The 4051 EMULATOR adds a small border around the drawing area that I cropped with MS PAINT and used MS PAINT to measure the drawing area with this image:
MS PAINT showed the upper left corner of this cropped image as 0,0 and the lower right corner as 1015, 797. The X=1015 certainly matches MDC FG doc X axis limit.
But I know that 4050 BASIC could write TEXT above the Y axis limit, so measuring the top right corner of the 0,0 to 100,100 bounding box I get 1015,16. If I subtract 16 from 797 I get 781 - matching MDC FG doc Y limit for graphics.
I was still curious why X limit = 1015 instead of 1023.
That answer is in the first line I displayed at the top of this post:
TEK 4050 BASIC GDUs for graphics are 0-130 for X and 0-100 for Y.
1015*0.128 = 129.92!
and 781*.128=99.968!
since 0,0 is an additional point here are my calculations for 1016x782:
1016x0.128 = 130.048!
782*0.128 = 100.096!
I had seen the 0.128 in the R12 manual, but wondered why 1023*0.128 = 130.944.
Now I know - I have been using slightly wrong scale factors for my 4050 BASIC programs like BITMAP, SVG and HPGL to R12!
In addition - I imagined that 4050 Graphics had square X and Y vector points - but 1015/4*3 = 761.25 not 781!
I have been using 1024x768 for the size of the 4050 graphics window - since I figured the extra points to the 780 resolution could be for the extra line of text at the top of the screen.
I was wrong again. My test results indicate the total vertical 'points' are 797+1=798 (since MS PAINT 0,0 is an additional point).
I tried MOVE 130,100 followed by PRINT "*" and nothing PRINTED past the 0,0 to 130,100 bounding box, but that could just be 4050 BASIC clipping.
I think I need to dust off my 47 year old assembly program I wrote to dump the 4051 ROMs using the X and Y D/A converters directly and see if I can print text (maybe even graphics?) past X=1015.
I also need to change my Convert HPGL to R12 program or the input data files to scale to 1016x782 X and Y vector points instead of 1024x768.
He stated:
100 INIT
110 WINDOW 0,130,0,100
120 PAGE
130 MOVE 0,0
140 DRAW 100,0
150 DRAW 100,100
160 DRAW 0,100
170 DRAW 0,0
180 MOVE 0,100
190 PRINT "PAGE FULL - Above Graphics"
200 HOME
210 FOR I=1 TO 7
220 PRINT " ";
230 A$=STR(I)
240 PRINT A$;
250 NEXT I
260 PRINT
270 FOR I=1 TO 6
280 PRINT "1234567890";
290 NEXT I
300 PRINT "123456789012";
310 MOVE 120,0
320 DRAW 130,0
330 DRAW 130,100
340 DRAW 120,100
350 PRINT ""
360 LIST 100,350
