GanjaTron
- Joined
- Jan 10, 2007
- Messages
- 201
Hi Monty,... and ran the ROM CRC Test, ALU Test and long and short RAM tests - all with no issues found.
... I have 4052 V5.1 ROMs - no patch ROMs and they all check out fine according to the list.
thanks again for the CRC crosscheck. I ran a series of CRC tests today and noticed I get different CRCs for U805A/B and U897A/B each run -- see attachments below (sorry for the crappy quality, I used my old iPad as backup digicam). The other ROMs match yours and the published values. I also have v5.1 running on (as I now discovered) a rev04 MAS; maybe that's not a valid combination. I have the rev09 on which the ROMs were originally installed as spare.
I also get SYSTEM ERRORs whenever I try the READ statement; that command defaults to device @34 (DATA statements) but actually reads from tape, then bails out with the error, probably after encountering a TRAP. The error code mentions what looks like an address in the 46XX range:
46XX is infact occupied by U805 and U897. I suspect these chips are actually installed on my MAS, even though they shouldn't be, and maybe even flaky on top of that. I understand these are patch ROMs which are no longer required for v5.1.
Looks like I will have to pull those boards again (*groan*) and check what's on the MAS. I may also have to swap for the rev09 board, all other things being equal...
Btw, any update on that dastardly display dilemma?
--Roland
