I had an experience with a failed -20V rail on the Display board of my 4052, the culprit was apparently a vias from the top to bottom layer of the PCB had failed and disconnected -20V from the XY deflection amplifiers. I've seen failed vias in 70s-80s car radios exposed to hot temperatures, but this is the first time I've seen a failed vias on a computer. But this computer was stored in a non-climate controlled Texas garage for a number of years before I had acquired it so I suspect the hot/cold temperature cycling may have weakened this vias connection.
The high level failure symptom I saw on the display was a dot in the center of the screen on power up. I noticed if you hit any character key repeatedly then suddenly the characters would start appearing but only as flat lines past the center point, and if you hit the Return key repeatedly to position the cursor to the lower right quadrant then the characters and cursor would appear on the screen normally. It looks like this:
https://electronixandmore.com/resources/teksystem/tek_display_neg20v_failure.jpg
Digging into the display board, I measured the I/O board producing X and Y deflection voltages in the range of approx +/-8V. The lower right quadrant of the display correspond to X and Y voltages that are below 0V (e.g. top half is Y>0V, left half is X>0). I traced the XY voltages from the I/O board through the amplifiers and noticed the final output stage that is powered by the unregulated +/-20V died when deflecting below 0V indicating a -20V rail failure. Also there is a 5.1V zener regulator off -20V to provide a ~-15V bias that was measuring +10V with respect to ground. What was puzzling to me at first was I had measured -20V as expected at the connector pin 8 of J54 on the display board. All the other power supply voltages at this connector even checked out OK. It wasn't until I measured the zener voltage that I realized -20V was not making it to the rest of the board and found a disconnection at the vias where the trace transitioned to the other side of the board. The fix was simply soldering in a jumper wire from the vias to a -20V point in the deflection circuitry, like this:
https://electronixandmore.com/resources/teksystem/tek_display_neg20v_failure_fix.jpg
It's one thing to see failed components, but a failed PCB trace...
