Terminal program that handle reader run signal?
Well, if the idea is a Molex connector that is panel-mount then here's a 3x4 matrix connector pair that's still stocked:
03-06-1121 Pin & Socket Connectors 12C RECEPTACLE (female, panel) 0.062 in - 5A
03-06-2122 Pin & Socket Connectors 12 CIRCUIT PLUG (male, free-hanging) 0.062 in - 5A
02-06-1103 Pin & Socket Connectors CRIMP SKT BULK 18-24 (female) 0.062 in - 5A
02-06-2103 Pin & Socket Connectors CRIMP PIN BULK 18-24 (male) 0.062 in - 5A
This search identifies a great number of 6-pin options, some of which may be panel mount:
https://www.mouser.com/c/connectors...ocket (Female)&number of positions=6 Position
A narrower search:
Unfortunately despite the picture this 6-pin socket doesn't include mounting ears:
This seems to be the replacement:
I didn't look for the matching plug. "Exercise left for the reader", if this is the type of connector that you seek :-}.
It is a challenging print, but I have successfully had these 3D printed in nylon:
The metal bits are a standard pin that is still in production.
Vince
A little late to the party, but I do have a fairly large number of either of these 1x8 connectors available (50+) and M/F pins (250+). See attached image.
I bought these connectors off eBay years ago and got a deal. Pins are from Mouser (still available). I've used a few but still have lots left. DM me if you are interested.
OR even better:
https://www.connectorpeople.com/Connector/TYCO-AMP-TE_CONNECTIVITY/1/1-480459-0 ... 500+ in stock, $0.86 each
https://www.connectorpeople.com/Connector/TYCO-AMP-TE_CONNECTIVITY/1/1-480460-0 ... 10K+ in stock, $0.78 each
