vprada
Thanks everybody for the guidance. I did try several apps, but the only one I could install on a floppy for testing was PCPaintBrush and indeed I was able to get a 640x400 resolution using the ATT video driver !!! this is a huge an interesting development.
I did create a little resident program I named QX16M24 which basically will implement the AX,0040 INT 10 call that enables the 640x400 video resolution in the M24 video card. The PCPaintBrush is actually making that BIOS call to force the machine to enter 640x400. After that the program renders at 640x400. Unfortunately I don't have a serial mouse to test as input device, so I could not load any drawings that would make the resolution difference more evident than what you may see in the two screenshots. (the mousek.exe that emulates a mouse is not working correctly for me)
So this experiment proves than the QX-11 & QX-16 CGA emulation cards use the same VRAM interlace mapping than the Olivetti M19/M24 and ATT Machines and take advantage of the full 32K of VRAM to reach a 640x400 monochrome resolution. I will need to test what possibilities exists for color rendering. Documentation says the QX-16 will do 16 colors at 160x100 but I will need to test that.
Can you mention any other business program that would take advantage of the 640x400 resolution on the ATT / Olivetti PCs ?
