cl3mens
A lot of people is moving out of the office where I work, and they are tossing a lot of fun things in the garbage.
I found what seems to be an old IBM paper tape punch, some unused paper tape and some other things. But I'm having trouble finding any information about the punch... The logo suggests that it's made between 1947 and 1956. Here is the only picture I found online (I will take some pictures of mine on monday):
The page http://w1tp.com/enigma/imcpue.htm has some info, but I'm hoping for more..
"1000 IBM HAND OPERATED PAPER TAPE PUNCH: (33KB) This rare grey metal unit punches holes into paper tapes, one hole at a time.
Ralph Reinke in Germany has provided an explanation of how this device was used. He writes: ''There were special paper tapes, a bit more than 12 inches long and with printed lines for indicating 'channels'. Into this tape holes were punched with this machine corresponding to height measures in preprinted forms. The tape was cut to length and glued as a ring, then inserted in a special part of the high speed printer. This paper ring was moved forward in sync with the forms and sensed channels by wire brushes. Whenever in the program an instruction 'skip to channel n' was encountered this resulted in the progression of the paper in one quick jump. This was all found in the famous printer IBM 1403 that belonged to the IBM 1401 system and was carried through many models through IBM /360 and /370. Later this paper ring went 'virtual' and a special data structure was invented that did the very same thing.''
Paul Pierce whose wonderful computer museum is located at: http://piercefuller.com/collect/ has also written to report that this device was used to prepare paper tapes which controlled the paper feed on accounting machines so they could print information in the correct locations on preprinted forms."
