glitch
album with descriptions: https://imgur.com/a/GDUR36j
A couple months ago, folks were discussing thicknet/10base5 on cctalk, and the topic of cable availability came up. I mentioned it to one of my local parts suppliers, who said he had a full roll of thicknet somewhere in the warehouse. Last week, this came home with me:
It's a full roll -- 1100 feet of Belden 89880 Ethernet cable! It's quite heavy Ethernet coax is its own thing, but is dimensionally similar to RG-8/U or LMR-400. N connector terminations intended for RG-8/U will work fine. I sourced a bunch of mil-spec AMP N female connectors for this project. Typically you see thicknet terminated in N male connectors, but using a female means you don't need a F:F joiner to hook the terminator on:
The quad shielding is especially fun to work with. I don't have a 3-level coax stripper that will handle cable this large, so I had to use one of my 2-level strippers and work it back a little further with a knife. I did manage to stick a braid strand into my finger and make it bleed. Hadn't had to touch thicknet since CCNA days in high school, and even then it was covered only because Cisco hadn't taken it out yet, and because the instructor thought we might have to one day tap in to an existing thicknet backbone. Still remembered how to do it, not that it's particularly complex. Here's the "close" end:
It's a Cabletron ST-500 transceiver with an AMP "non-intrusive" vampire tap kit, which makes it the ST-500-01. It's "non-intrusive" because you don't have to cut the cable to install it. You bolt the tap on, core out a hole for the "stinger" contact, and then screw the stinger contact in with the other end of the coring tool. Then it bolts to the transceiver. Remember to set the SQE (heartbeat) switch, or you have to remove the tap from the transceiver! The AUI cable on the left goes to the Sun-proprietary AUI port on the SPARCstation 10. Yes, I did have to connect to IRC over thicknet
This is the "far" end, the DEChub 90 relocated to a stack of boxes near the end of the thicknet cable. Another Cabletron ST-500 here as well, connected to a DECbridge 90FL module, which provides AUI and 10baseFL fiber. This was too far away from the Cisco 2801 router that the DEChub usually talks to, via a DECbrouter 90T1, so I just connected it to the main network over 10baseT with a DECrepeater 90TS.
So, there you go, a thicknet segment brought up in 2018! Required tools include the AMP 228917-1 coring tool, hex key (comes with AMP tool), N connector crimp dies (I used Paladin 2039 dies in a CrimpALL 8000 frame), wire cutters, coax stripper and/or knife, small screwdriver, and heavy cable cutters. I've got around 1080 feet of Belden 89880 coax, so if anyone is wanting their own thicknet cable, PM me! I can provide any level of "kit," from just the cable up to crimped-on N connectors, terminators, and tap kits. I have a very few Cabletron ST-500-01 transceiver/tap kits new in the box, including the instruction manual. The one thing I don't have a bunch of is AUI cables, but I have a source online that I'm happy to pass on.
If you want to install your own vampire taps but don't want to buy the AMP tool for it, you *can* use a drill and a steady hand.
