I have a Chinese Tillamook (mobile late Pentium, naturally at 266Mhz, I usually clock it at 300Mhz) that I got from eBay. It's a nice chip, but will only run quickly provided the board has the appropriate multiplier/bus. Any idea if there's a way to get or make a small interposer to change the multiplier on these manually, i.e., so I can run at 66Mhz bus x4.5 to get 300Mhz, or x4 to get 266Mhz?
Sidenote: YEAAAAH Pentium section!
Edit: It's worth noting that iirc the chip itself is designed for a 66Mhz bus with a 4x multiplier, so a 4x multiplier is doable, just a matter of if it can be hacked onto a board that doesn't support it.
