jknightandkarr
- Joined
- Nov 9, 2023
- Messages
- 138
I have 2 systems, neither seam to work even on a CRT tv. I composite modded 1 with transistor and resistors, the other with the computer/tv box and adapter to conmect to tv, will check caps, but what are common issues that might cause them to not function? I've heard ULA's can overheat and fail. Should I try there or start with the Z80 inside n connect to my logic analyzer on the data pins n see what happens at power up? Thanks.
