nikola-wan
Thanks to the generosity of Walter Devaney - I have a working TransEra 741-RTC Real-Time-Clock ROM pack for my Tektronix 4054A computer.
Here is a photo of the TransEra 741-RTC ROM Pack. The module uses the Hitachi CMOS HD146818 real time clock IC:
The gold fingers were a bit tarnished on the edge connector - so I carefully rubbed them with a white rubber eraser from Staedtler #526 50 UP (eraser crumbs are visible in the next photo).
Before plugging into my Tektronix 4054A - I unbolted the ROM pack case and saw that the three small NiCAD batteries were corroded, and the battery pack voltage was near zero.
I did some cleaning of the battery corrosion, and reseated all the socketed ICs.
I also tried to charge the NiCADs, but they quickly began to discharge.
I checked the resistance of the module across the +5V and GND edge connector contacts - and the board (one Tantalum capacitor) was ok.
I first powered on my 4054A and verified it was still working.
Then turned off the 4054A and waited for several seconds - and plugged in the 741-RTC ROM pack.
I turned the 4054A back on and ran the CALL "CLIST" command (only in the 4052A and 4054A, underlined characters are actually typed as Control characters) and did not see any new CALLs for the 741-RTC.
I then powered off the 4054A, reseated the ROM pack, turned on the 4054A a couple more times, but did not see any new CALLs - which means the ROM pack was not detected.
Then I turned off the 4054A, unplugged the ROM pack for a closer examination.
I unsoldered the tantalum capacitor and found it checked out ok with my Fluke meter capacitor test function.
I reinstalled the capacitor and reseated all three socketed ICs again.
After inserting the cartridge and powering on my 4054A - I saw the new BASIC CALLs - highlighted in yellow:
There were a lot more calls than the cartridge label indicated.
I tried the first command in the list: 741RTC and it indicated Firmware version 1.3 from 1984.
I had some TransEra manuals included with a shipment of tapes I received in 2001 after I first purchased my Tektronix - and I had the Real Time Clock Operators Manual!!
I decided to type in the test program listed in the appendix and everything worked!
The tests include:
- Read Clock Commands (date and time)
- Extended Read Clock Commands (seconds, weekday, day and month)
- Clock Mode Commands (12 versus 24 hour, standard versus daylight savings)
- Timer Commands (PAUSE)
- CMOS Memory Read/Write Commands
- PERIOD interrupt Commands
- TIMER interrupt Commands
- ALARM interrupt Commands
- Power-Up String (loads and runs your program loaded into RTC CMOS at powerup)
Only the WEEKDAY was wrong - and the Hitachi datasheet indicates parts with an "X" do not support daylight savings time, but the rest of the commands worked great!
Here is the listing of the test program - I will also upload it to my github repository for recovered Tektronix 405x programs:
Walter also sent me several other TransEra ROM cartridges for the Tektronix 4052/4054:
- Super Utilities
- four A/D Converters with the Differential Connector panel
- Auxiliary Memory (only the ROM pack - he didn't have the actual memory module)
I have already cleaned the contacts of the Super Utilities ROM and got a dump of all the CALL commands - 78 in all!
I'll start a new thread about that cartridge.
Monty
The tests include:
1 REM RTC.TEK -- Test the New 641/741RTC ROM Pack
2 GO TO 100
80 REM Interrupt Routine Entry Points for PERIOD, TIMER, and ALARM
90 GO TO 1310
91 GO TO 1520
92 GO TO 1790
100 PAGE
110 PRINT "641/741 Real Time Clock Test Program"
120 PRINT
130 PRINT "1. Read Firmware Level and Set Clock"
140 PRINT " Firmware message ";
150 IF INT(RND(0)*10)<>1 THEN 180
160 CALL "641RTC"
170 GO TO 190
180 CALL "741RTC"
182 PRINT " Enter date&time: Example:27-APR-19 10:00:00 ";
184 INPUT B$
188 REM CALL "!SETTIME","04-APR-19 10:00:00"
190 CALL "!SETTIME",B$
200 PRINT
210 PRINT "2. Simple Read Clock Commands"
220 PRINT
230 PRINT " Current Date and Time=";
240 CALL "!DATETIME"
250 CALL "!DATETIME",B$
260 PRINT " Date and Time String=";B$
270 PRINT
280 PRINT " Current Date=";
290 CALL "!DATE"
300 CALL "!DATE",B$
310 PRINT " Date String=";
320 CALL "!DATE",D,T,Y
330 PRINT " Numbers=";D;T;Y
340 PRINT
350 PRINT " Current Time=";
360 CALL "!TIME"
370 CALL "!TIME",B$
380 PRINT " Time String=";B$;
390 CALL "!TIME",H,M,S,B
400 PRINT " Numbers=";H;M;S;B
410 PRINT
420 PRINT "3. Extended Read Clock Commands"
430 PRINT
440 CALL "!SECONDS",N
450 PRINT " Current Seconds=";N;
460 CALL "!TIME",H,M,S,B
470 CALL "!SECONDS",H,M,S,N
480 PRINT " Find Seconds=";N
490 PRINT
500 CALL "!WEEKDAY",N
510 PRINT " Current Weekday Number=";N;
520 CALL "!WEEKDAY",B$
530 PRINT " String=";B$
540 CALL "!WEEKDAY",D,T,Y,N
550 PRINT " Find Weekday Number=";N;
560 CALL "!WEEKDAY",D,T,Y,B$
570 PRINT " String=";B$
580 PRINT
590 CALL "!DAY",J
600 PRINT " Current Julian Day=";J
610 CALL "!DAY",D,T,Y,J
620 PRINT " Find Julian Day=";J
630 CALL "!MONTH",J,Y,D,T
640 PRINT " Julian Day=";J;" Year=";Y;" Day=";D;" Month=";T
650 PRINT
660 PRINT "4. Clock Mode Commands"
670 PRINT
680 CALL "!24HOUR"
690 CALL "!STANDARD"
700 PRINT " Should be 24 Hour Standard-";
710 CALL "!MODES"
720 CALL "!12HOUR"
730 PRINT " Should be 12 Hour Standard-";
740 CALL "!MODES"
750 CALL "!24HOUR"
760 CALL "!DAYLIGHT"
770 PRINT " Should be 24 Hour Daylight Savings-";
780 CALL "!MODES"
790 CALL "!STANDARD"
800 PRINT " Should be 24 Hour Standard-";
810 CALL "!MODES"
820 PRINT " End of Modes Test"
830 PRINT "Press Carriage Return to Continue.";
840 INPUT B$
850 PAGE
860 PRINT "5. Timer Commands"
870 PRINT
880 PRINT " PAUSE Test 10 Seconds"
890 PRINT " Start Time=";
900 CALL "!TIME"
910 CALL "!PAUSE",10
920 PRINT " End Time=";
930 CALL "!TIME"
940 REM
950 PRINT
960 PRINT " CMOS Memory Test"
970 FOR I=1 TO 40
980 CALL "!WRITE",I,I
990 NEXT I
1000 FOR I=0 TO 3
1010 PRINT " ";
1020 FOR J=1 TO 10
1030 P=I*10+J
1040 CALL "!READ",N,P
1050 PRINT N;
1060 IF P=N THEN 1090
1070 PRINT " Number Error P/J=";P;J
1080 STOP
1090 NEXT J
1100 PRINT
1110 NEXT I
1120 PRINT " Pass Byte Read/Write"
1130 B$="TEST STRING"
1140 CALL "!WRITE",B$,1
1150 CALL "!READ",C$,LEN(B$),1
1160 IF C$=B$ THEN 1190
1170 PRINT "CMOS STRING ERROR B$/C$=";B$;C$
1180 STOP
1190 PRINT " ";B$,C$
1200 PRINT " Pass String Read/Write"
1210 PRINT
1220 PRINT " Test PERIOD interrupt at 1 Hz"
1230 I=0
1240 PRINT " ";
1250 CALL "!PERIOD",1,90
1260 REM PROCESSING LOOP
1270 J=0
1280 IF I>20 THEN 1350
1290 J=J+1
1300 GO TO 1280
1310 REM PERIOD INTERRUPT ROUTINE
1320 I=I+1
1330 PRINT "*";
1340 RETURN
1350 CALL "!PERIOD"
1360 PRINT
1370 PRINT " End PERIOD Test J=";J
1400 PRINT
1410 PRINT " TIMER Interrupt Test for 10 seconds"
1420 PRINT " Start at ";
1430 CALL "!TIME"
1440 I=0
1450 CALL "!TIMER",10,91
1460 REM PROCESSING LOOP
1470 J=0
1480 IF I>0 THEN 1560
1490 J=J+1
1500 GO TO 1480
1510 REM TIMER INTERRUPT ROUTINE
1520 PRINT " TIMER Interrupt !! at ";
1530 CALL "!TIME"
1540 I=1
1550 RETURN
1560 PRINT " End TIMER test J=";J
1590 PRINT
1600 PRINT " Start ALARM Interrupt Test at ";
1610 CALL "!TIME"
1620 I=0
1630 CALL "!TIME",H,M,S,B
1640 S=S+10
1650 IF S<60 THEN 1700
1660 S=S-60
1670 M=M+1
1680 IF M<60 THEN 1700
1690 H=H+1
1700 CALL "!ALARM",H,M,S,92
1710 CALL "!RALARM",J,H,M,S
1720 PRINT " ALARM Set to ";H;":";M;":";S
1730 REM PROCESSING LOOP
1740 J=0
1750 IF I>0 THEN 1830
1760 J=J+1
1770 GO TO 1750
1780 REM ALARM INTERRUPT ROUTINE
1790 PRINT " ALARM Interrupt !! at ";
1800 CALL "!TIME"
1810 I=1
1820 RETURN
1830 CALL "!ALARM"
1840 PRINT " End ALARM test J=";J
1860 PRINT
1870 PRINT " Power-Up String Test"
1880 B$="1FORJ=1TO10 2PRIJ 3NEXJ RUN "
1890 C$=CHR(13)
1900 B$=REP(C$,12,1)
1910 B$=REP(C$,18,1)
1920 B$=REP(C$,24,1)
1930 B$=REP(C$,28,1)
1940 CALL "!SETPU",B$,1
1950 PRINT " Please turn OFF the power switch,"
1960 PRINT " and then turn it back ON."
1970 PRINT " Don't forget to CALL ""!SETPU"" after the test"
1980 PRINT " to clear the power up string test"
- Super Utilities
Monty
