DavidWien
I have bought a Kaypro II, and when I have got it running as it should, I intend to use it for writing text with Perfect Writer. I used to do this in the 1980s with my first Kaypro, and wrote substantial documents with it. The documents I am now writing will need to be transferred to Word and sent to my publisher (who does all the pretty formatting).
In the fullness of time I expect to be using an HXC floppy emulator and I am not sure what would be the best way of transferring the text to the PC. Here are what in my naivety I imagine to be possible methods:
-- Put the SD card into the Drive B reader on my PC.
-- Transfer files via serial port to USB input.
-- Transfer files via Ethernet or WIFI.
Once on the PC, I will refine the text files in EMACS and transfer them to Word. (This is the part of the process that I know well!)
To start with I shall be using my Kaypro unmodified, using option 2 or 3. It may be that option 1 is not viable at all, so when the HXC is running I would then continue using option 2 or 3.
Many thanks for your advice.
David
David
