Hi All,
I have managed to pick up the RK and the other Stuff.
Here are a first overview about the Unibus stuff - some of them are more than once in the box.
Some cool cards in, as the Rx02, Unibus Extender, complete RK611, DEUNA, UDA50, and the needed cables.
Part Vendor Description
M5904 DEC MASSBUS control transceiver
G7273 DEC Bus Grant & Non-processor grant
G180 DEC Pack read/write (RK05)
G938 DEC PAK HEAD POSITION SERVO PREAMP (RK05)
M7485 DEC UNIBUS to radial disk interface PR board with blasted ROMs
M7486 DEC Controller for SDI disk drives (UDA SI)
M7792 DEC DEUNA port module, UNIBUS to ethernet microprocessor. (1 of 2)
M7793 DEC DEUNA link module, M7792 to ethernet bus line unit. (2 of 2)
M7814 DEC 8-line 20mA data MUX, 50 to 100-Kbaud
M7821 DEC "Fast M7820 Interrupt control, 7-bits, 1 per PDP11 peripheral (Replaced by M7821)
M7900 DEC RK06/07 Unibus interface, hex
M7901 DEC RK06/07 register module, hex
M7902 DEC RK06/07 control module, hex
M7904 DEC RK06/07 data module, hex
m7904 DEC RK06/07 drive interface module, hex
M7911 DEC TMB11 tape control 1
M7912 DEC TMB11 tape control 2
M8123 DEC 11/70 ROM & address control, FP11-C compatible
M8130 DEC 11/70 data paths module
M8131 DEC 11/70 general registers and ALU control
M8132 DEC 11/70 instruction register decode & condition Code
M8134 DEC 11/70 processor data & UNIBUS registers module
M8135 DEC 11/70 trap and miscellaneous control module
M8136 DEC 11/70 UNIBUS and console control module
M8137 DEC 11/70 system address path module
M8138 DEC 11/70 segmentation status register
M8139 DEC 11/70 timing generator module
M8140 DEC 11/70 segmentation and console control module
M8141 DEC 11/70 mapping box
M8142 DEC 11/70 cache control board
M8143 DEC 11/70 cache address memory board
M8144 DEC 11/70 cache data memory
M8145 DEC 11/70 cache data path
M8150 DEC 11/70 MASSBUS data path module
M8151 DEC 11/70 MASSBUS control and status module
M8152 11/70 MASSBUS address and word count registers
M8153 DEC 11/70 MASSBUS UNIBUS control (M8150-M8153 is option RH55 in an 11/55)
M8256 DEC RX02 floppy disk controller
M9202 DEC UNIBUS connector, inverted (M9192+M9292 assembled 1" apart with 2' cable)
M9302 DEC 11/04 UNIBUS terminator, far end (Fits in any Standard UNIBUS slot, terminating all newer UNIBUS machines.)
M9302 DEC Terminator for PDP11 bus, 120-ohm to +3V, 1000pf on BF1 & BF2
Many Greetings
Ulrich
