SiriusHardware
I dusted off my original ZX81 a few weeks ago and powered it up - still working so I was pondering what to do next.
Nowadays it should be easier to create and test software, especially machine language software, on an emulator before converting it into a form that a real ZX81 can load, so with that thought in mind I downloaded the 'Eighty One' emulator for Windows and it runs up fine, and if I go and fetch a .TZX file from the likes of 'ZX81 Stuff', that loads and runs fine through 'File / Load Tape'.
However, if I type in a six line BASIC program and then name and save it through File / Save Tape, which does successfuly create a .tzx file with the name I choose, I can't then load it back in again with File / Load Tape. The load routine goes through the motions of auto-typing 'Load ""' and then goes through to the classic 'dancing lines' load screen (as though waiting to start reading something in from tape) but it never loads the .TZX and therefore does not exit from the load screen.
What am I doing wrong?
'Eighty One' version is V1.41, OS is Win10 64 bit - allthough Eighty One is a 32-bit program it seems to run OK from the point of letting me type a BASIC program in, letting me run the BASIC program, and letting me load a .TZX file from an online source. The only thing I can't get it to do is to load a .TZX that it has saved itself.
Anyone else running this ZX81 emulator? What happens if you try the same, type in and save a short BASIC program then try to reload it?
