Is there anyone that would like to test my Model 4 CP/M Plus and give me feedback? I'm to the point where I want to make sure it works on systems other than my 4D. You'll need to have familiarity with CP/M and the ability to write DMK images to real disks.
One particular system I need it tested on is a 4P. The disk format I used 30+ years ago was five 1K sectors per track. Later when I got a 4P I found out the 4P ROM had a bug where floppies with 1K sectors were assumed to be for Model III mode and therefore required loading MODELA/III. I patched the ROM but now don't have a 4P with the original. I've changed to a disk format with ten 512-byte sectors and want to see if an unmodified 4P will boot it without requiring MODELA/III or hitting key combinations to bypass. If I remember correctly (it's been 20 years since I first got the 4P) the key combination to bypass loading the Model III ROM image did not work. It may have just been that the key combinations worked but it was just a pain to do it every time I booted.
These are DMK floppy images. Due to a bug in the xtrs and TRS32 floppy emulations it won't work on the current released versions of either (or sdltrs which uses the xtrs source). Both Tim Mann and Matthew Reed have fixed the bug in their emulators. Matthew Reed is still working on some other updates and hasn't released the updated version of TRS32 yet but Tim Mann has an updated version of xtrs on GitHub. I haven't been able to build a fixed copy of sdltrs on my Mac since the versions of Xcode I have won't compile it.
Send a PM if you would like to test. The source will be released at a later point.
