I managed to successfully build the project in the end under a Debian 11 VM.So I’ve almost completed the hardware portion of my Trs-io and like others am having problems compiling the esp32 project. I’m using vs code and am getting exasperated with bad cmake errors. Any advice?
The main thing I did to get it to compile was to use v4.3.3 of esp-idf, other versions caused the build to fail near the end.
The attached file contains the steps I followed which originally came from here, I then altered with the esp-idf version and where the bin files are created.
Good luck,
Tim
