Chromedome45
How do I bypass the LS-DOS/TRS-DOS 6.x config/sys file? the disks I have are trying to talk to a Hard drive by way of SYSGEN which I do not have connected. At the moment. Any help appreciated.
You can override any breakable AUTO function during power up or reset by holding down <ENTER> during initialization. This may be your only way of regaining control of the system, if the dos-command is not a working program. If the AUTO function disables the <BREAK> key and the AUTOed program is non-functional, it may seem impossible to regain control of that disk. Should this occur, simply BOOT another (non-AUTOed) disk in drive 0. When the LDOS READY appears, place the non-functional disk in drive 0, type AUTO, and press <ENTER>. The runaway AUTO function will then be removed from that disk.
