I have several machines in my collection that have been repaired by simply replacing TTL components on various boards.
One Altair 8800 was fixed when a friend helped me by tracing through the TTL on the front panel to isolate and replace a bad component or two.
Another Altair 8800 that I recently recieved had bad TTL on both the processor board and the front panel board. Fortunately both of those were socketed so I was able to isolate the bad parts fairly quickly.
The same was true of an Altos in my collection. One bad TTL part kept the machine from booting.
With that said, I have two questions:
1. What causes these parts to go bad? On the second Altair and on the Altos there was no reason for the parts to fail other then pure age. No spikes, static or other abuse could/should have caused it since there was none. The other Altair may have been poked the wrong way at some point.
2. Having replaced these busted components with newer ones, where can one find older date-coded parts without tearing up other old machines? I'd like to keep my collections as close to pristine as possible which, to me, means keeping the date codes for the parts within reason.
Any ideas or comments?
Erik
Erik
