Hi,
I have one of those Taiwanese XT clone boards like the one discussed in this Russian forum
http://www.phantom.sannata.ru/forum//index.php?t=26329
But mine looks much better
despite of its gorgeous appearance it does not boot Appareance it's not everything
I have followed minuszerodegrees Minimum Diagnostic Configuration (is this trademaked or patented? ) with the following results:
- There are no beeps
- PSU fan works (I know for sure that the PSU it's OK since I got it from a working system)
- I do not have a multimeter to check voltages but some chips on the board get warm included the 8088-1 so I think there are not shorted capacitors
- I have tested several RAM chips on bank 0 (I left populated only this bank) unsuccessfuly
- I have noticed that the the DM74S74N flip flop in U39 gets extremely hot It burns when touched and I was afraid that it would catch fire
Se the photo:
Any ideas ?? Could this be the root cause of the MB failure?
Thanks
BTW the MB has a stick over the BIOS chip that read TD3.91, there is this BIOS dump on minuszerodegrees:
View attachment td393.zip
Se the photo:
Thanks
and in the Russian forum they have posted version TD3.93 I repost it here in case there is someone interested (I have tested it on PCem and boots fine)BIOS source Motherboard: Unbranded XT clone (CPU: 8088 @ 4.77 MHz)
Supplier giobbi at the Vintage Computer Forums
BIOS chip type 2764
BIOS contains the strings "86 © TD3.86 ID: 75102637"
"COPAM © 1985"
"Author: Thomas Lao"
Comment BIOS chip is labelled: TD 03.86
Download Clone XT BIOS - TD3.86 ID 75102637.bin
