Ultra-low-resistance cable for Kaypro keyboard
clh333
Cleveland, OH, USA
This topic was previously discussed in 2013 at here: http://www.vcfed.org/forum/showthread.php?36372-kaypro-4-keyboard-cable
I have several Kaypros but n-1 keyboard cables so I went to an office supply and bought a telephone receiver cord as a substitute. It worked for one machine (a 10) but not for others (a II and a 4/83). The Kaypro TSM (Aug. 85, p 13-1) mentions that "The impedance of the connecting cable can be a critical factor in proper operation of the computer. Replacement of the standard cable with a phone cord can create malfunctions in signal transmission to the computer. This is because the wire in phone cords is too small: therefore, the impedance over the total length of the card can be too high for reliable operation."
I measured my replacement cable against one of Kaypro's own. Although low in impedence (<10 Ohms) it was an order or two of magnitude higher than Kaypro's (0.1 Ohm). I have also read that the early Kaypros had slightly undernourished power supplies (mine is nominally 60 Watts) and since the cable provides +5V to the keyboard I suppose that even 10 Ohms of resistance might cause unstable operation of the keyboard system.
So much for theory. My question is more practical: Does anyone know where I can get an ultra-low-resistance cable, preferably coiled, preferably in the same length as the Kaypro standard (nominally six feet extended) and preferably terminated with the RJ9 connectors?
Thanks for your replies.
-CH-
RJ9 is the four conductor, not six conductor modular plug, right?
I'm asking because I have some NOS keyboard cables but they have the six connector plug on one end and the usual 5 pin DIN on the other.
attachment.php
Thanks for your reply.
Monster, out of SF, replied to my inquiry saying they do not make such a cable. I was unable to find one on eBay, either. Know of a place to look?
-CH-
I'm sorry- the smiley face wasn't obvious enough. Monster cables are always good for a friendly argument. I'm not sure what is special about that cable, but I'm sure we can find a proper substitute. You might have to find a wiring guy to crimp some ends on a less flexible cable or something, though.
I replaced my coiled Kaypro 2X keyboard cable decades ago. For me, the coiled cable was a pain. You can't ever take full advantage of the true electrical length, and the cable kept getting caught in the stand and restricting keyboard placement. I forget if it actually started to fail or I just had had enough and replaced it with a straight cable.
I crimped a couple 4p4c connectors on some decent, stranded, phone cable and watched the length carefully.
